VS Code "ERROR: Unable to load devices: null" error. Any suggestions for fix?
Hi,
I am new to Garmin Connect IQ and this forum. I just want to create a customized watchface and wanted to give it a try. Followed the instructions on https://developer.garmin.com/connect-iq/reference-guides/visual-studio-code-extension/ and also downloaded latest version of SKD and all devices using SKDManager. Even though I have followed all the steps when I run the code the simulator does not open and I get the following error. I am sure that I have added all the devices to the code. What do you guys recommend me to check?
usage: monkeyc [-a <arg>] [-b <arg>] [--build-stats <arg>] [-c <arg>] [-d <arg>]
[--debug-log-level <arg>] [--debug-log-output <arg>] [-e]
[--Eno-invalid-symbol] [-f <arg>] [-g] [-h] [-i <arg>] [-k] [-l <arg>]
[-m <arg>] [--no-gen-styles] [-o <arg>] [-O <arg>] [-p <arg>] [-r] [-s
<arg>] [-t] [-u <arg>] [-v] [-w] [-x <arg>] [-y <arg>] [-z <arg>]
The terminal process "C:\Program Files (x86)\Common Files\Oracle\Java\javapath\java.exe '-Xms1g', '-Dfile.encoding=UTF-8', '-Dapple.awt.UIElement=true', '-jar', 'c:\Users\mustafa\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-6.2.1-2023-06-26-124cb49c5\bin\monkeybrains.jar', '-o', 'bin\olmadi_1.prg', '-f', 'c:\Users\mustafa\Documents\deneme1\olmadi_1\monkey.jungle', '-y', 'h:\garmin_test_1\deneme1\developer_key', '-d', 'fr255_sim', '-w'" terminated with exit code: 101.
