Batch Compile/Export
After an SDK update, I generally re-export my Barrels, then recompile and export all my CIQ apps.
Right now I have to do this one at a time. I have 4 barrels and a bunch of fields. That is a whole lot of time to wait for each to complete before starting the next.
Anyone have a Windows BAT file that automates these actions to compile and export a list of projects?
Thanks!
  • Here's a modified version of what I use. Windows CMD scripting is terrible compared to bash or even powershell, so I didn't bother to make it fancy.
    export.bat
    @echo off
    setlocal EnableDelayedExpansion
    rem Usage: export PROJECT_FOLDER_WITH_JUNGLE [ADDITIONAL_FOLDERS_WITH_JUNGLES...]
    rem Edit the following 2 lines
    set EXPORTPATH=PATH\TO\EXPORT\FOLDER
    set DEVKEY=PATH\TO\DEV\KEY
    for /F "tokens=* USEBACKQ" %%F in (`type "%appdata%\garmin\connectiq\current-sdk.cfg"`) do (
      SET CIQSDKPATH=%%F
    SET JUNGLES=
    for %%d in (%*) do (
      for %%j in (%%d\*.jungle) do (
        set JUNGLES=!JUNGLES!%%j;
    rem Use project folder name as export filename
    for %%A in (%1) do (set PROJECT_FOLDER_NAME=%%~nxA)
    @echo on
    "%CIQSDKPATH%\bin\monkeyc" -o "%EXPORTPATH%\%PROJECT_FOLDER_NAME%.iq" -e -w -y "%DEVKEY%" -r -f "%JUNGLES%"
    The java executable has to be in your path for this to work.
    If it isn't, replace the final two lines (starting with @echo on) with:
    SET JAVA=\PATH\TO\JAVA
    @echo on
    "%JAVA%" -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar "%CIQSDKPATH%\bin\monkeybrains.jar" -o "%EXPORTPATH%\%1.iq" -e -w -y "%DEVKEY%" -r -f "%JUNGLES%"
    export_all.bat (example usage of export.bat)
    pushd
    cd /D "%~dp0"
    call .\export AwesomeProject1
    call .\export AwesomeProject2
    REM build a project which has jungle files in two folders (AwesomeLibrary is not a barrel)
    call .\export AwesomeProject3 AwesomeLibrary
    popd
    Folder structure for this example:
    dev\
    |--- projects\
            |-------export.bat
            |-------export_all.bat
            |-------AwesomeProject1\
            |            ---- monkey.jungle
            |-------AwesomeProject2\
            |            ---- monkey.jungle
            |-------AwesomeProject3\
            |            ---- monkey.jungle
            |-------AwesomeLibrary\
                         ---- monkey.jungle
    I don't use barrels, so not sure if you'll need to tweak anything to get barrels to build.
