I need help
Hi, everybody
I need your help, because I'm programing a watch face with setting, and in the simulador settings works perfectly but I install the watch face in my garmin and in Garmin Conect Mobile is not showed the menu of setings to change the configuration the watch face. Which part of the code I'm forgetting and which file I'll must write it?
Thanks for all and your help
  • When you sideload something, you can't use GCM or GE to do app settings. There's a file involved, but it comes from the app store There are a couple things you can do though.
    1) create the .set file in the simulator can copy it to the watch (\garmin\apps\settings folder)
    2) upload your app to the store, and in the description include "DO NOT APPROVE". You'll be able to download it while it's in the pending state, but no one else can. You'll be able to then use CGM or GE to test app setting when you download from the store. When you're happy with how it works, remove the "DO NOT APPROVE"
