please ignore / delete
  • There should be a "supported devices" in the api doc for the call.  I suspect that this call isn't available on the f5+, kind of like how Weather is "since API Level 3.2.0", but not on the f5+, so a doc error is my guess...
  • Hi I found I had a problem on my system whereby I didn't have the SDK versions loaded that I thought I had. Once I fixed this I found 4.1.17 at least works as expected.
    I did update the question (couldn't find how to delete it myself?) as soon as I realised, but you must have seen it beforehand. Sorry to have taken your time but thanks for responding.
  • You always want to use the current SDK, which is 4.2.4.  While it may work with 4.1.7, it not being available on 4.2.4 could have been a bug fix.  Do you have an actual f5+ to try it on?
  • I do have an F5+, I mentioned in my original question (which I realise you can't see now) I was getting the same problem on the simulator and the real device.
    For now 4.1.7 is the latest version that I can get to run on my system --- higher versions give me a segmentation fault when I try to run the simulator via the `connectiq` command.
    I have a relatively unusual environment, at least it seems in the Garmin/CIQ world (Void Linux/Vim/command line). It's been difficult but I've not asked questions about getting my general environment working, as I appreciate that my difficulties might be seen as self-inflicted and I don't want to get into philosophical debates about software choice.
    I'm very happy to have a working environment now, and my app (including `getUserActivityHistory()`) is working in the simulator and on my real device.
    I appreciate your advice about keeping my SDK up-to-date and will check regularly that I am at least using the latest version that I can get to work on my system.
