Hello,
Does anyone want to share the code that calculates Moon Times? (rise and set)
Thanks,
Hello,
Thanks,
hi, it is in js but here is a start:
function calculateMoon(moment, lat, lng)
var rise, set;
var nextInfo = Gregorian.info(moment, Time.FORMAT_SHORT);
var options =
:year => nextInfo.year,
:month => nextInfo.month,
:day => nextInfo.day,
:hour => 0,
:minute => 0,
:second => 0
var date = Gregorian.moment(options);
var hc = 0.133 * RAD;
var h0 = getMoonPosition(date, lat, lng) - hc;
var h1, h2, a, b, xe, ye, d, roots, x1, x2, dx;
for(var i=1; i<=24; i+=2)
var duration1 = new Time.Duration(i * Gregorian.SECONDS_PER_HOUR);
var date1 = date.add(duration1);
var duration2 = new Time.Duration((i+1) * Gregorian.SECONDS_PER_HOUR);
var date2 = date.add(duration2);
h1 = getMoonPosition(date1, lat, lng) - hc;
h2 = getMoonPosition(date2, lat, lng) - hc;
a = (h0 + h2) / 2 - h1;
b = (h2 - h0) / 2;
xe = -b / (2 * a);
ye = (a * xe + b) * xe + h1;
d = b * b - 4 * a * h1;
roots = 0;
if (d >= 0)
dx = Math.sqrt(d) / (a.abs() * 2);
x1 = xe - dx;
x2 = xe + dx;
if (x1.abs() <= 1)
roots++;
if (x2.abs() <= 1)
roots++;
if (x1 < -1)
x1 = x2;
if (roots == 1)
if (h0 < 0)
rise = i + x1;
else
set = i + x1;
else if (roots == 2)
rise = i + (ye < 0 ? x2 : x1);
set = i + (ye < 0 ? x1 : x2);
if (rise != null && set != null)
break;
h0 = h2;
var durationRise = new Time.Duration(rise * Gregorian.SECONDS_PER_HOUR);
var dateRise = date.add(durationRise);
var nextRise = Gregorian.info(dateRise, Time.FORMAT_SHORT);
System.println(nextRise.hour + ":" + nextRise.min);
var durationSet = new Time.Duration(set * Gregorian.SECONDS_PER_HOUR);
var dateSet = date.add(durationSet);
var nextSet = Gregorian.info(dateSet, Time.FORMAT_SHORT);
System.println(nextSet.hour + ":" + nextSet.min);
return dateRise;
function getMoonPosition(moment1, lat, lng)
var lw = RAD * -lng;
var phi = RAD * lat;
var dd = moment1.value().toDouble() / DAYS - 0.5 + J1970 - J2000;
var L = RAD * (218.316 + 13.176396 * dd); // ecliptic longitude
var M = RAD * (134.963 + 13.064993 * dd); // mean anomaly
var F = RAD * (93.272 + 13.229350 * dd); // mean distance
var l = L + RAD * 6.289 * Math.sin(M); // longitude
var b = RAD * 5.128 * Math.sin(F); // latitude
var e = RAD * 23.4397;
var ra = Math.atan2(Math.sin(l) * Math.cos(e) - Math.tan(b) * Math.sin(e), Math.cos(l));
var dec = Math.asin(Math.sin(b) * Math.cos(e) + Math.cos(b) * Math.sin(e) * Math.sin(l));
var H = RAD * (280.16 + 360.9856235 * dd) - lw - ra;
var h = Math.asin(Math.sin(phi) * Math.sin(dec) + Math.cos(phi) * Math.cos(dec) * Math.cos(H));
if (h < 0)
// the following formula works for positive altitudes only.
return h; // if h = -0.08901179 a div/0 would occur.
return h + 0.0002967 / Math.tan(h + 0.00312536 / (h + 0.08901179)); // altitude correction for refraction
I used that code but it doesn't display correct times. Here is the code translate in MonkeyC
I've just tested you code and I am good at around 2min.
Didn't you chnage anything in the code?
For me isn't working. For rise I have a difference of about 30 min and for set aroung 4 hours
no, I haven't change anything, except the way you deal with date, but even with your way it is ok,
did you use double for the coordinates?
Thank you for your time.
I have found where the error was. I was seding the LAN and LNG in radians which wasn't correct.
