Moment Type Casting Crash
Hi,
I am working on an app that reacts to tap events, averaging the time between the taps. I am having trouble with storing the difference between two Moment values.
The first tap registers correctly, and
setupLastTime = Time.now().value();
is executed correctly with the proper value.
on the second tap,
setupThisTime = Time.now().value();
executes, but the app crashes on
beatTime += (setupThisTime - setupLastTime).toDouble();
with the error
UnexpectedTypeException: Expected Number/Float/String/Long/Double, given Object/Double
found in the logs.
I guess I'm not quite sure how types work in Monkey C.
Any help would be much appreciated, as this is my first Connect IQ app! ^^
  • beatTime += (setupThisTime - setupLastTime).toDouble();
    Ok, so your taking two "unix times", subtracting them, and giving you a number in seconds.
    You're then taking a number, converting it to a double and adding it to beatTime. What is beatTime? How is beatTime defined?
    Former Member over 9 years ago
    beatTime is declared with all of my other variables in the class before the initialize() function.
    var beatTime;
    it is then initialized as a Double (I believe?) in the onLayout() function
    beatTime = 0.0;
  • beatTime is null...
    Try
    var beatTime=0.0d;
    if you really want a double. But why do you need it to be a double? It will only be a number which will easily fit in 32 bits.
    var beatTime=0;
    should also work...
    I'm not sure what you mean about it being initialized in onLayout()...
    beatTime is null...
    Try
    var beatTime=0.0d;
    var beatTime=0;
    should also work...
    even if I store the times as Moments and use the built in subtract function,
    beatTime += (setupThisTime.subtract(setupLastTime).value().toDouble());
    I still get this error
    UnexpectedTypeException: Expected Number/Float/Long/Double, given Object
    and cannot seem to cast to the proper type in any way.
    I have been having trouble with this for a few days now.
    It needs to be a Double as it is the sum of differences between the unix times (sadly i believe i can only be as precise as seconds in Monkey C), which, at the end of a timer, is divided by the number of differences to compute the average difference, which may or may not be an integer.
    If I had to guess I would say that the size of the numbers could have something to do with it?
  • It's likely because where you have
    var beatTime;
    and beatTime is null and you need
    var beatTime=0.0;
    You can verify this by adding:
    Sys.println("beatTime="+beatTime);
    before you try to change it, so see what it is and what this change does.
    var beatTime;
    var beatTime=0.0;
    Turns out I was assigning beatTime in two different places, and one was still a Duration.
    Seems like this bug is fixed.
    Thank you for your prompt responses and for your suggestion, it led me down the right path for sure.
  • No Problem...
    But keep the Sys.println() concept in mind, as that can tell you a bunch about what's going on in the code.
    And I'm still not sure why you need a double for this, BTW... Why not just use a number?
    Former Member over 8 years ago
    If you want more precise timing, you can use the free running millisecond timer from the system to compute the time difference.
    It is accessed with Toybox.System.getTimer()
