handling bimaps for Garmin watch face
Hello, I am new to Garmin watch faces.
I have started bulding one, and i would like to know how to handle bitmaps.
i can load the background image for my watch, and then the complications for hours, minutes and seconds.
But they are static, i want to know how to display them dynamically according to the current time.
and wether i should do that in the onUpdate() function or somwhere else.
Thank you)
  • Even if my watch face does complications, I just use the standard API calls for the time.  And yes, do it in onUpdate.
    in VS Code, do a Monkey C:New project and then watch face, and you'll see a very basic example of displaying the time.
    If you want "seconds all the time", look into onPartialUpdate.  See https://forums.garmin.com/developer/connect-iq/f/discussion/5156/1hz-watch-faces---q-a
    onPartialUpdate isn't available on AMOLED devices.
    Once you have the time, again in onUpdate, you can change the bitmaps based on the time.  A different on at different times.
    Former Member in reply to jim_m_58
     thank you for your reply.
    yeah i have succeded the first steps and already starting working on it.
    tha app was dispalying the background and the complications all in the center, but now when i tried to make the complication's positions dynamic somehow am stcuk and the complications are no longer displayed:
    import Toybox.Graphics;
    import Toybox.Lang;
    import Toybox.System;
    import Toybox.WatchUi;
    class Garmin_watchView extends WatchUi.WatchFace {
    var background_bitmap;
    var timeLocX;
    var timeLocY;
    var hourComplication;
    var minuteComplication;
    var secondComplication;
    var batteryComplication;
    var stepsComplication;
    var heartComplication;
    function initialize() {
    WatchFace.initialize();
    background_bitmap = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.background_bitmap,
    :locX=>0,
    :locY=>0
    hourComplication = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.hourComplication,
    :locX=>0,
    :locY=>0
    minuteComplication = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.minuteComplication,
    :locX=>0,
    :locY=>0
    secondComplication = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.secondComplication,
    :locX=>0,
    :locY=>0
    batteryComplication = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.batteryComplication,
    :locX=>0,
    :locY=>0
    stepsComplication = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.stepsComplication,
    :locX=>0,
    :locY=>0
    heartComplication = new WatchUi.Bitmap({
    :rezId=>Rez.Drawables.heartComplication,
    :locX=>0,
    :locY=>0
    timeLocX = 300;
    timeLocY = 180;
    // Load your resources here
    function onLayout(dc as Dc) as Void {
    setLayout(Rez.Layouts.WatchFace(dc));
    // Called when this View is brought to the foreground. Restore
    // the state of this View and prepare it to be shown. This includes
    // loading resources into memory.
    function onShow() as Void {
    // Update the view
    function onUpdate(dc as Dc) as Void {
    dc.clear();
    // Draw the background image
    background_bitmap.draw(dc);
    drawWatchFace(dc);
    var clockTime = System.getClockTime();
    var timeString = Lang.format("$1$:$2$", [clockTime.hour, clockTime.min.format("%02d")]);
    dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_TRANSPARENT);
    dc.drawText(
    timeLocX,
    timeLocY,
    Graphics.FONT_MEDIUM,
    timeString,
    Graphics.TEXT_JUSTIFY_CENTER
    // Called when this View is removed from the screen. Save the
    // state of this View here. This includes freeing resources from
    // memory.
    function onHide() as Void {
    // The user has just looked at their watch. Timers and animations may be started here.
    function onExitSleep() as Void {
    // Terminate any active timers and prepare for slow updates.
    function onEnterSleep() as Void {
    function drawWatchFace(dc) {
    var currentTime = System.getClockTime();
    var centerX = dc.getWidth() / 2;
    var centerY = dc.getHeight() / 2;
    var radius = 100; // Adjust the radius as needed
    // Calculate the angles for hour, minute, and second
    var hourAngle = (360 / 12) * (currentTime.hour % 12);
    var minuteAngle = (360 / 60) * currentTime.min;
    var secondAngle = (360 / 60) * currentTime.sec;
    // Calculate the X and Y coordinates for each complication
    var hourComplicationX = centerX + (radius * Math.cos(Math.toRadians(hourAngle)));
    var hourComplicationY = centerY + (radius * Math.sin(Math.toRadians(hourAngle)));
    var minuteComplicationX = centerX + (radius * Math.cos(Math.toRadians(minuteAngle)));
    var minuteComplicationY = centerY + (radius * Math.sin(Math.toRadians(minuteAngle)));
    var secondComplicationX = centerX + (radius * Math.cos(Math.toRadians(secondAngle)));
    var secondComplicationY = centerY + (radius * Math.sin(Math.toRadians(secondAngle)));
    // Draw the hour complication bitmap
    dc.drawBitmap(hourComplicationX, hourComplicationY, hourComplication);
    // Draw the minute complication bitmap
    dc.drawBitmap(minuteComplicationX, minuteComplicationY, minuteComplication);
    // Draw the second complication bitmap
    dc.drawBitmap(secondComplicationX, secondComplicationY, secondComplication);
  • Ok, so you aren't using Complications, and it's just an analog WF for now.  Have you looked at the analog sample in the SDK?
    am not sure about what you mean with analog WF.
    the analog sample is the default watch with numeric time shown when you first launch the app?
  • In the SDK folder, there is a folder called "samples", and one of those sample projects is named "analog"
    in the sdk folder i have bin folder and resources folder and none of them contains samples.
    i will try to look elsewhere  for the folder.
    Former Member in reply to Former Member
    i have seen on my ubuntu machine but now am workin with my windows one and i found it under Windows: %APPDATA%\Garmin\ConnectIQ\Sdks.
    I will check it.
    thank you)
    wow this already looks complicated, and in my case i am not drawing them.
    i already have images for the hour, minute and second and i should make them rotate over the background image...
    is this something i can consider or is it a waste of resources? the idea is to load images with different angles since i couldn't figure out how to rotate clock ticks images until now
    var hourHandImages[12];
    var minuteHandImages[60];
    var secondHandImages[60];
    // Initialize hour hand images
    for (var i = 0; i < 12; i++) {
    hourHandImages[i] = new WatchUi.Bitmap({
    :rezId => Rez.Images.hourHandImage[i],
    :locX => 0,
    :locY => 0
    // Initialize minute hand images
    for (var i = 0; i < 60; i++) {
    minuteHandImages[i] = new WatchUi.Bitmap({
    :rezId => Rez.Images.minuteHandImage[i],
    :locX => 0,
    :locY => 0
    // Initialize second hand images
    secondHandImages[i] = new WatchUi.Bitmap({
    :rezId => Rez.Images.secondHandImage[i],
    :locX => 0,
    :locY => 0
    // Other initialization code
    // Get the current time
    var currentTime = System.getTime();
    // Get the hour, minute, and second values
    var hour = currentTime.hour;
    var minute = currentTime.min;
    var second = currentTime.sec;
    // Draw the hour hand
    hourHandImages[hour].draw(dc, hourLocX, hourLocY);
    // Draw the minute hand
    minuteHandImages[minute].draw(dc, minuteLocX, minuteLocY);
    // Draw the second hand
    secondHandImages[second].draw(dc, secondLocX, secondLocY);
