How to add a new data field to an existing watch face?
I have a Garmin D2 Air X10 watch. When customizing the default watch face you have the option of setting the data fields for the 3 data field 'slots' on the watch face. You can choose between things like weather, steps, battery, etc. I want to add a new (custom) data field as an option for these slots, but when I go through the process of creating a data field and installing on my watch, it is not listed as an option when customizing the watch ui.
Is this even possible? Or am I probably not doing something correctly?
(See this Garmin tutorial for the specifics of the section I am referring to.)
Alternatively, if it's impossible for new data fields to be added to default watch faces, does Garmin have a repository of default watch faces in Monkey C somewhere where I use as a basis?
