Hi, I'm getting fed up with crashes because of property type change between app release or bad data return in a JSON object from makeWebRequest, so I wrote the following two functions to deal with that (I have one for each main type (number, float, string and boolean). How would you improve upon it? I tried to make it generic instead of having one set per type I'm validating against but was unable to find a way. The validate can even handle dictionaries or arrays passed at them instead of a number (they don't have a toNumber method). In that case, it returns the default value.
function getNumberProperty(key, defaultValue) {
var value;
try {
value = Properties.getValue(key);
catch (e) {
value = defaultValue;
return validateNumber(value, defaultValue);
function validateNumber(value, defaultValue) {
if (value == null || !(value has :toNumber)) {
} else if (!(value instanceof Lang.Number)) {
try {
value = value.toNumber();
catch (e) {
if (value == null) {
return value;
For boolean, it's a bit different since there is no toBoolean method but Numbers are accepted so this seems to work with all the cases I threw at it
function validateBoolean(value, defaultValue) {
} else if ((value instanceof Lang.Boolean) || (value instanceof Lang.Number)) {
try {
if (value) {
value = true;
else {
value = false;
catch (e) {
else {
return value;
The 'if' inside the 'try' could be an overkill though.
