Edge Datafield running more than one instance
Hi there!
I‘m developing datafields for Edge devices. On an Edge device you have usually 3 or 4 activity profiles: Road, Mountainbike, Indoor and so on.
In general, it is not a problem to use one and the same data field in several profiles.
But it becomes a problem if the profile is changed during a running recording without save or exit the first activity - and so the data field is loaded in second instance. (Yes, users really do that!)
This leads to problems with data playback.
Now my question:
Is there a way for data fields to check if it is simultaneously loaded another time? So, to determine if one instance is already running while another one is to be loaded?
Thanks!
