So the following background running code generated a System Error on a Fenix 6X Pro at the "else if (responseCode == 408)". What makes this line different than the others? Why not the 401 line just above it???
var suffix;
if (responseCode == 200 && responseData != null) {
: reading responseData here, skipping it for the sake of simplicity here
suffix = "";
else if (responseCode == 401) {
suffix = Application.loadResource(Rez.Strings.label_launch_widget);
else if (responseCode == 408) {
suffix = Application.loadResource(Rez.Strings.label_asleep);
else {
suffix = Application.loadResource(Rez.Strings.label_error) + responseCode;
All three string resources in the code above are defined with 'scope="background"' and the watch language was English. If I emulate this watch,it works flawlessly.
It's frustrating trying to make a program reliable when things like that happen :-<
