I'm having some issues wiring up my app correctly in 4.2.3. I guess a lot has changed, but I'm not sure how to know what to correct in my modules/imports/usings.
I've fixed all the compile time issues by moving a number of my usings to imports and then also explicitly importing toybox.lang in certain cases.
However, when I run my app, code in one module fails to find other modules sitting in the same folder. I didn't previously have import statements for these, and adding them doesn't seem to work.
For example, these two files sit next to one-another.
/appconstants.mc
module AppConstants{
public const DATA_VIEW_1_ID="data_view_1";
/appconfig.mc
module AppConfig{
public function getFieldSettings(id){
var settings =[];
if(id==AppConstants.DATA_VIEW_MAP_ID){
settings= [Properties.getValue("map_field1"),
Properties.getValue("map_field2")];
When I run this, the AppConstants are undefined in the AppConfig.mc file and it instantly crashes. Do I need to reference them explicitly somehow, or with some different syntax?
