Hello,
I bought a new Mac and copied my Garmin apps over. I installed the SDK and VS Code. The app, unmodified says it cannot find a file which is there (it was a relative position, so no complex directory change). When I then moved the image to the same directory and fixed the bitmap line, I had to use sudo to save it. It still did not work.
I gave VS all file permissions in System Settings, Privacy and Security, and granting it Full Disk Access. I also did Instal 'code' command in path inside VS Code. The only other thing I can think of is that it is having problems with FileVault being on.
Thoughts?
Thanks,
Jeff
