I tried the example given in the doc exactly as it was written:
// It is common for developers to wrap a makeWebRequest() call in a function // as displayed below. The function defines the variables for each of the // necessary arguments in a Communications.makeWebRequest() call, then passes // these variables as the arguments. This allows for a clean layout of your web // request and expandability. using Toybox.System; using Toybox.Communications; // set up the response callback function function onReceive(responseCode, data) { if (responseCode == 200) { System.println("Request Successful"); // print success } else { System.println("Response: " + responseCode); // print response code }; }; function makeRequest() { var url = "https://www.garmin.com"; // set the url var params = { // set the parameters "definedParams" => "123456789abcdefg" }; var options = { // set the options :method => Communications.HTTP_REQUEST_METHOD_GET, // set HTTP method :headers => { // set headers "Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED}, // set response type :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_URL_ENCODED }; var responseCallback = method(:onReceive); // set responseCallback to // onReceive() method // Make the Communications.makeWebRequest() call Communications.makeWebRequest(url, params, options, method(:onReceive)); }
But I get:
BUILD: ERROR: extraneous input ';' expecting '}'
BUILD: ERROR: extraneous input ';' expecting {<EOF>, 'class', 'module', 'using', 'import', 'alias', 'typedef', 'public', 'const', 'native', 'var', 'enum', 'function', '('}
I tried to fix the semicolons and put all inside a class:
// It is common for developers to wrap a makeWebRequest() call in a function // as displayed below. The function defines the variables for each of the // necessary arguments in a Communications.makeWebRequest() call, then passes // these variables as the arguments. This allows for a clean layout of your web // request and expandability. using Toybox.System; using Toybox.Communications; class Test { // set up the response callback function function onReceive(responseCode, data) { if (responseCode == 200) { System.println("Request Successful"); // print success } else { System.println("Response: " + responseCode); // print response code } } function makeRequest() { var url = "https://www.garmin.com"; // set the url var params = { // set the parameters "definedParams" => "123456789abcdefg" }; var options = { // set the options :method => Communications.HTTP_REQUEST_METHOD_GET, // set HTTP method :headers => { // set headers "Content-Type" => Communications.REQUEST_CONTENT_TYPE_URL_ENCODED}, // set response type :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_URL_ENCODED }; var responseCallback = method(:onReceive); // set responseCallback to // onReceive() method // Make the Communications.makeWebRequest() call Communications.makeWebRequest(url, params, options, method(:onReceive)); } }
But now I am getting:;Invalid '$.Toybox.Lang.Method(responseCode as Any, data as Any) as Any' passed as parameter 4 of type 'PolyType<(callback(responseCode as $.Toybox.Lang.Number, data as Null or $.Toybox.Lang.Dictionary or $.Toybox.Lang.String) as Void) or (callback(responseCode as $.Toybox.Lang.Number, data as Null or $.Toybox.Lang.Dictionary or $.Toybox.Lang.String, context as $.Toybox.Lang.Object) as Void)>'.
No idea what to do now. Why is the example not compiling?
