SDK 4.2.x String not defined in language default
Just tried to compile using 4.2.1 (and .2 and .3) and am getting the error below.   I haven't seen this before and it does not occur in 4.1.x SDK's
String ID xxxxx not defined for language "DEFAULT'
the twist is the strings it is complaining about are NOT in the monkey.jungle file paths I have setup for the devices it is complaining about.   somehow it is looking at strings i have for higher memory devices that are in completely different folders.  If i put these in the main strings.xml, the error goes away, but then i'm including strings not needed for some apps and will probably have memory problems in the lower memory devices.
file structure is more or less like this
resources/strings -> base strings for all devices
highmem/strings -> extra strings for high mem devices
monkey.jungle for low mem is just pointing to resources/strings
and the compiler error is a low mem device complaining about strings in the highmem/strings folder
highmem devices compile just fine
i'll keep using the 4.1.7 SDK for now as that isn't causing any errors, but looks like some newer devices want the 4.2 sdk
