If so, how do I do it? And where can I find some animation samples?
Thanks in advance.
using Toybox.Application as App;
using Toybox.Lang as Lang;
using Toybox.System as Sys;
using Toybox.WatchUi as Ui;
using Toybox.Graphics as Gfx;
using Toybox.Math as Math;
class Square extends Ui.Drawable
var rotation;
var scalex;
var scaley;
var color;
function initialize(params) {
Drawable.initialize(params);
rotation = 0.0;
scalex = 1.0;
scaley = scalex;
color = params.get(:color);
if (color == null) {
color = Gfx.COLOR_RED;
function draw(dc) {
var ax = width / 2;
var bx = width - ax;
var ay = height / 2;
var by = height - ay;
// points are pre-scaled
var points = [
[ -ax, -ay ],
[ bx, -ay ],
[ bx, by ],
[ -ax, by ]
// rotate
var c = Math.cos(rotation);
var s = Math.sin(rotation);
for (var i = 0; i < points.size(); ++i) {
var x2 = (points[0] * c) - (points[1] * s);
var y2 = (points[1] * c) + (points[0] * s);
points[0] = x2;
points[1] = y2;
// scale
points[0] *= scalex;
points[1] *= scaley;
// translate
points[0] += locX;
points[1] += locY;
dc.setColor(color, Gfx.COLOR_TRANSPARENT);
dc.fillPolygon(points);
function reset() {
rotation = 0.0;
scalex = 1.0;
scaley = scalex;
class ZZZDelegate extends Ui.BehaviorDelegate
hidden var view;
function initialize(view) {
BehaviorDelegate.initialize();
self.view = view;
function onSelect() {
view.animate();
class ZZZView extends Ui.View {
function initialize() {
View.initialize();
animating = false;
hidden var square;
function onLayout(dc) {
var dx = dc.getWidth();
var dy = dc.getHeight();
var size = (dx < dy ? dx : dy) / 4;
var params = {
:locX => dc.getWidth() / 2,
:locY => dc.getHeight() / 2,
:width => size,
:height => size,
:color => Gfx.COLOR_BLUE
square = new Square(params);
function onUpdate(dc) {
dc.setColor(Gfx.COLOR_WHITE, Gfx.COLOR_WHITE);
dc.clear();
square.draw(dc);
hidden var animating;
function animate() {
if (!animating) {
animating = true;
Ui.animate(square, :rotation, Ui.ANIM_TYPE_EASE_IN_OUT, 0.0, 2 * Math.PI, 5.0, self.method(:onAnimationComplete));
Ui.animate(square, :scalex, Ui.ANIM_TYPE_EASE_IN_OUT, 1.0, 3.0, 5.0, null);
Ui.animate(square, :scaley, Ui.ANIM_TYPE_EASE_IN_OUT, 1.0, 3.0, 5.0, null);
function onAnimationComplete() {
animating = false;
// reset back to original size
square.reset();
Ui.requestUpdate();
class ZZZApp extends App.AppBase {
AppBase.initialize();
function getInitialView() {
var view = new ZZZView();
var delegate = new ZZZDelegate(view);
return [ view, delegate ];
[/code]
The Ui.animate() function just changes the value a member variable and calls Ui.requestUpdate() several times over the specified period. If you want to rotate a drawable, you need that drawable to be able to render itself given a rotation angle. Once you can do this, you can just apply an animator to it.
Here is a working example...
var rotation;
var scalex;
var scaley;
var color;
rotation = 0.0;
scalex = 1.0;
scaley = scalex;
function draw(dc) {
var ax = width / 2;
var points = [
[ -ax, -ay ],
[ bx, -ay ],
[ bx, by ],
[ -ax, by ]
// rotate
points[0] = x2;
points[1] = y2;
// scale
// translate
points[0] += locX;
points[1] += locY;
function reset() {
rotation = 0.0;
scalex = 1.0;
scaley = scalex;
hidden var view;
self.view = view;
view.animate();
View.initialize();
animating = false;
hidden var square;
var params = {
:width => size,
:height => size,
dc.clear();
square.draw(dc);
if (!animating) {
animating = true;
animating = false;
square.reset();
Ui.requestUpdate();
[/code]
Thanks for the example. But the question is, can I use your method to rotate a bitmap drawable?
