OWM Call problem...
Good day,
I am trying to create an OWM function in my Watch Face to call Current and Daily weather data.
Can someone advise me where I am making a mistake and if it is at all possible to call data via:
api.openweathermap.org/.../weather
and
https://api.openweathermap.org/data/2.5/onecall ???
Here they attach their code that doesn't work.
Thank you
BG.service.zip
  • You don't seem to be calling either getWeatherDaily() or getWeatherCurrent() from onTemporalEvent, so you are never issuing the request.
  • And could I ask you for help with this code please?
    I don't know how to deal with it...
    Thank you
  • Make this your onTemporalEvent function:
    	function onTemporalEvent() {
    		System.println("Started onTemporalEvent..");
            getWeatherCurrent();
    and move this to inside your getWeatherCurrent() function (at the top)
    //right after System.println("Getting data for last known coordinates");
     		var units = "metric";
    		if (System.getDeviceSettings().temperatureUnits == System.UNIT_STATUTE){
    			units = "imperial";
  • So I modified it and I only get calls from Function getWeatherCurrent();
    but because the function getWeatherDaily();
    not yet.
    Is it possible to call two at the same time?
  • I wouldn't do them at the same time,  but I'd cain them, where in onReceiveOWMCurrent(), if the responseCode==200, call getWeatherDaily() instead of doing Background(exit) (with the same change for "units", then in the callback for that call, combine it with the responst from getWeatherCurrent() and do a Background.exit of the combine responses.
