Good morning,
Reading through the Class / Method info on garmin website about FIT developer fields, it states "the information can be displayed in Garmin Connect as a per-second graph". I wanted to confirm with someone who has used it that other units are available other than seconds on the X axis?
For example, if I did 10 sets of weights, but wanted to graph the rep number I could do that?
If I am graphing a field value, I noticed it says Apps are limited to 256 total bytes per message.
If passing Numbers with one decimal, how do I figure out the byte number use?
Could I graph 100 or 200 values for example?
