Fail to store value in device WatchFace
Hello,
I develop a watch face and I use in watch setting menu, with function getSettingsView().
I want to save the settings into the application storage, which works fine in the simulator, but fails on the device.
Is there a special trick to apply?
Sample code which fails, if comment the Application.Storage.setValue command then all works fine on the watch :
import Toybox.Application;
import Toybox.Lang;
import Toybox.WatchUi;
class sampleWatchFace extends Application.AppBase {
    function initialize() {
        AppBase.initialize();
    // onStart() is called on application start up
    function onStart(state as Dictionary?) as Void {
    // onStop() is called when your application is exiting
    function onStop(state as Dictionary?) as Void {
    function getInitialView() as Array<Views or InputDelegates>? {
        // Fails on the device with a black screen with the Connect IQ icon:
        Application.Storage.setValue("testKey","testValue");
        return [ new watchFaceView() ] as Array<Views or InputDelegates>;
    function onSettingsChanged() as Void {
        WatchUi.requestUpdate();
    function getSettingsView() as Array<Views or InputDelegates>? {
        var delegate = new MyMenuDelegate();
        var menu = new WatchUi.Menu2({:title=>"Options"});
        menu.addItem( new MenuItem( "Opt1", null, "opt1", {} ) );
        menu.addItem( new MenuItem( "Opt2", null, "opt2", {} ) );
        menu.addItem( new MenuItem( "Opt3", null, "opt3", {} ) );
        return [ menu, delegate ] as Array<Views or InputDelegates>;
