I need to update my WatchFace view only when settings change. How do I do it?
Hi I'm trying to implement settings on my watch face but I don't want to load settings on every onUpdate() but just onLayout() or when they changed.
My code works in the emulator but it's not working on a device.
Here is how I implemented it:
class MyApp extends Application.AppBase {
    hidden var _view = new MyView();
    // Return the initial view of your application here
    function getInitialView() as Array? {
        return [ _view ] as Array;
    // New app settings have been received so trigger a UI update
    function onSettingsChanged() as Void {
        _view.onSettingsChanged();
Could you help me?
EDITED - January 14th, 2023:
[SOLVED]
To make the code example simpler, and focused on the investigated problem, I omitted here in this post some lines of my full code.
Unfortunately, the real problem was in one of those lines, where the _loadResources() method was called.
As _psx_ pointed out, the problem with this is the attempt to load resources (a storage operation) outside of onLayout().
Also, _psx_ also pointed out the problem with instantiating my View outside of my App class's getInitialView().
Below is my incorrect code, still simplified, but with these problems (red lines):
class MyView extends WatchUi.WatchFace {
    private var _lastMinute = 0;
    private var _propertiesChanged = false;
    function onLayout(dc as Dc) as Void {
        _loadResources();
        _loadSettings();
    public function onSettingsChanged() as Void {
        _loadResources();
        _loadSettings();
        _propertiesChanged = true;
        requestUpdate();
    function onUpdate(dc as Dc) as Void {
        var clockTime = System.getClockTime();
        if ((clockTime.min != _lastMinute) || _propertiesChanged) {
            _draw(dc);
        _lastMinute = clockTime.min;
And below is the correct code:
    hidden var _view;
         _loadResources();
        _loadSettings();
         // REMOVED _loadResources()
         _loadSettings();
        requestUpdate();
            _draw(dc);
The full source code can be seen here:
https://github.com/eldes/presbyopia-watch-face
