HTTPS makeWebRequest - 404, in browser ok or 401
Hi!
I've already used ok some api requsts recently, then I needed to change url for another host + request, but got 404.
- in browser i got 401 for just url (see code), because no auth header its ok and its not 404 as I got in simulators.
- curl:
curl -H "Host: www.ukrposhta.ua" -H "Authorization: Bearer c3e02b53-3b1d-386e-b676-141ffa054c57" --compressed "https://www.ukrposhta.ua/status-tracking/0.0.1/statuses?barcode=0501698463278"
gives 200 and json (array of objects).
but in Connect IQ it just says 404 in the end in onReceive method.
Any ideas why ?
    function makeRequest() {
        var url = "https://ukrposhta.ua/status-tracking/0.0.1/statuses?barcode=0501695505620";
        var options = {
            :method => Comm.HTTP_REQUEST_METHOD_GET,
            :headers => {
                    "Content-Type" => Comm.REQUEST_CONTENT_TYPE_JSON,
                    "User-Agent" => "UkrPoshta/1 CFNetwork/1107.1 Darwin/19.0.0",
                    "Authorization" => "Bearer c3e02b53-3b1d-386e-b676-141ffa054c57"
        if (Comm has :makeWebRequest) {
           // in modern watches its executed
            Comm.makeWebRequest(url, null, options, method(:onReceive));
        } else {
            Comm.makeJsonRequest(url, null, options, method(:onReceive));
    function onReceive(responseCode, data) {
        var code = responseCode;
Any ideas why ?
I even tried to use parameter barcode in as separate variable for request
var url = "https://www.ukrposhta.ua/status-tracking/0.0.1/statuses";
and
var params = { "barcode" => "0501698463278"};
same 404 Disappointed
curl -H "Host: www.ukrposhta.ua" -H "Authorization: Bearer XXXXX" --compressed "https://www.server.com"
