Any idea of the problem?
What do you see in garmin/app/logs/ciq_log.yml when you try the store download on a device?
To understand the stack trace when all you have are the pc values, see https://forums.garmin.com/developer/connect-iq/f/discussion/231129/so-you-have-a-ciq_log-file-but-all-you-see-is-pc-without-a-friendly-stack-trace---what-to-do
I knew Jim will send this ;)
maybe that link should also be pinned to the forum
Thank jim.
I have already solved the lines that the log informed me, the log does not exist anymore, does that indicate that everything is correct?
The .yml get's renamed .bak when it's been synced to generate ERA reports. If you look at the .bak, it's what was in the yml. This also means you might see this in your ERA reports, but there can be a delay - and there the pc values are translated for you.
