Where is the downloaded SDK samples located or how do I get it please.
for a First Connect IQ App?
To be clear, the command palette is the box that opens when you press CTRL-SHIFT-P, which explains why you don't get any results when you type "command palette" into the command palette.
You'll find that it supports "fuzzy search", which means you can type something like "mcosa" to match "Monkey C: Open Samples Folder"
Yes I know this but like I keep repeating nothing is coming up with it! why I'm on here asking for help!
Has you can see! :-)
sorry for this why I was asking as I rthought there somthing not quite right here!
There was also another command in the tutorial that sais press ctrl + F5 and that ended up losing all my settings in Chrome and firefox for strange reasons too. this was teh sortcut command for Run without Debugging!
In the box at the top of what I posted , start typing sample and you'll see this:
Then click on the first item you see in this screen shot. In your first screen shot it's almost like your looking for command palette (which you are already in) instead of the samples.
