All, I know there has been many discussions about the VA and open water swimming over the past few years and it not being supported and that the data is inaccurate etc...
I wanted to take the time t layout what I have been able to find with my testing and see what Garmin support has to say. I tried the normal support route and kept going in circles with them understanding the issue and kept telling me that open water swimming is not available on the VA and then pointed me here.
I am using an application "jtriathlon" that was derived from pmtriathlon with some enhancements.
The CIQ SDK has the option for open water swimming and that is what I am using.
The data however logs almost twice the distance that was actually swam and I have been trying to find out why.
I can understand if it was less as the GPS does not always have a signal and it may have missed a data point while turning a buoy or something.
The details are as follows:
I swam about 500 yards wearing BOTH a 910 and a VA at the same time. The 910 recorded about 500 yards and the VA recorded about 900 yards.
I exported the VA data to GPX format and using the GPS coordinances captured, manually added the distance with an online calculator and came up with about 500 yards. go figure. if I can do it, why cant garmin connect.
Next step, I uploaded what was exported back into Garmin connect and now the data reads about 500 yards (or .34 miles compared to .32 miles for the 910) so I would say close enough. so, the export may have corrected some invalid/corrupted data but in the process it removed about 1 minute from the time.
I am thinking that something is mangled on the import but it handles it without notice and it would be good to know what is going on in the FIT file.
Are there any FIT file readers available that show in plain text (like xml) before doing anything with it?
Any ideas? I think I am on to something but need the support of others. Many people are looking for support for open water swimming with the VA. Triathletes like their data and they like it to be correct :)
wearing the watch tucked in your swim cap might be a short term solution or doing and export/import might also.
I would like to help figure what is happening and what might be done to resolve it.
Again, I can see if the distance was shorter because of the drop outs but should not be longer than the data given. sounds like some bad logic or a corrupted file.
I am pretty sure this was happening before I updated this app but in case it wasn't, the work around I did to just stop and start activities without formally saving them may be an issue here however it does save all the data.
Thanks,
John
