new SDK version (4.1.7) and new firmware, will it cause problem?
Good day.
I would like to ask some technical information about the new SDK version (4.1.7).
I have applications written in CIQ that work without issue. I run into problems by switching the SDK to a new version, to avoid this I turned off the check like this:
project.typecheck = 0
The question is, now I'm using the new SDK (4.1.7) and everything works as it should, but what if Garmin releases a different firmware (CIQ 5), does aplkication stop working for me, or does it
depend on the minSDK"" parameter in the manifests. xml file?
Thanks for the replies and advice.
  • Actually, it depends on neither.  What you built should continue to run as-is.  Let's say a device gets a 3.4 VM and you built for a 3.2,  It should still run fine.  minSDK/minAPI is just a minimum.  The 4.1.7 SDK can be used to build apps for any device that supports CIQ, but different devices run different versions of CIQ.  Don't confuse the SDK version with a device's CIQ level.
  • Great, thanks for the info, it helped me a lot.
