Is the Descent Mk2 S really at level 3.3.0?
Hi all,
I am developing a watch face for my Descent Mk2 S, and trying to add sunrise and sunset times when I find they are not supported.
I then added the latest SDK's and set the project manifest to 3.3x, and The Descent is greyed out in the build targets.
https://developer.garmin.com/connect-iq/compatible-devices/ states that the Descent is at 3.3.0 so I am confused.
Can anyone help?
Thanks and Best Regards
Al
  • Sounds like you're using Eclipse, since I don't think VS Code works like this. I just tried it with minApiLevel = 3.3.0 and the Descent Mk 2 S device was available. As a sanity check, I changed the min level to 4.0.0 and confirmed that the device was greyed out.
    Is it possible you don't have the latest device files?
    Try opening the device's compiler.json file:
    - For Windows, this is at:
    %APPDATA%\Garmin\ConnectIQ\Devices\descentmk2s\compiler.json
    - For macOS, this is at:
    /Library/Application Support/Garmin/ConnectIQ/Devices/descentmk2s/compiler.json
    The partNumbers and worldWidePartNumber properties should have the following contents:
        "partNumbers": [
                "connectIQVersion": "3.3.1",
                "firmwareVersion": 1410,
                "languages": [
                        "code": "ara",
                        "fontSet": "ww"
                        "code": "bul",
                        "fontSet": "ww"
                "number": "006-B3542-00"
                "connectIQVersion": "3.2.0",
                "languages": [
                        "code": "eng",
                        "fontSet": "ww"
                        "code": "ind",
                        "fontSet": "ww"
                        "code": "zsm",
                        "fontSet": "ww"
                        "code": "zhs",
                        "fontSet": "apac_chn"
                        "code": "zht",
                        "fontSet": "apac_twn"
                        "code": "jpn",
                        "fontSet": "apac_jpn"
                        "code": "kor",
                        "fontSet": "apac_kor"
                        "code": "tha",
                        "fontSet": "apac_tha"
                        "code": "vie",
                        "fontSet": "apac_vie"
                "number": "006-B3930-00"
        "worldWidePartNumber": "006-B3542-00"
    If not, you must somehow have an outdated version of the device files. Open the SDK manager, delete the device if necessary, and redownload it. (If you don't have auto-updates enabled, I suggest turning them on.)
    EDIT: You will note that the Asia-Pacific (APAC) model of the product is still at 3.2.0, which means that if you set the min API level to 3.3.0, users with an APAC model will be unable to download it. Other users will have the worldwide (WW) model, which is at 3.3.1 as per compiler.json. I did try editing the languages to see if choosing a language which is only available in the APAC device -- such as zhs (Chinese - Simplifed) -- would cause the device to become unavailable given the min API level of 3.3.0, but nothing like that happened (which is what I expected).
  • Thanks FlowState, my file was out of date even though I had auto-update on both SDK and devices. Its whirring through as we speak and I suspect that will fix the problem. You learn something every day except for the days you don't.
    Thanks again
