Hi,
First time experience with Monkey C.
I did not succeed to build my first app, on my machine
- OS : macOS Monterey 12.6
- Visual Studio Code v1.73.1
- Monkey C extension v1.0.7
- Connect IQ SDK v4.1.7
- Java version "1.8.0_351"
Java(TM) SE Runtime Environment (build 1.8.0_351-b10)
Java HotSpot(TM) 64-Bit Server VM (build 25.351-b10, mixed mode)
Steps that i have tried several times, but still to no avail
- Get SDK manager from https://developer.garmin.com/connect-iq/sdk/
- Download the latest Connect IQ SDK (v4.1.7), and set as current SDK
- Download the watches/wearable device i want to develop.
- Install Monkey C extension for VS Code
- Monkey C extension Installation verified.
- Generate and set developer_key
- Following step-by-step Your First Connect IQ app
I'm always stuck at this point. This is my Terminal output after calling Run without debugging. ERROR: InputStream cannot be null
* Executing task in folder HelloWorld: java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /Users/JRENG!/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.7-2022-11-21-562b8a195/bin/monkeybrains.jar -o bin/HelloWorld.prg -f /Users/JRENG!/Documents/Digital Poems/Garmin/HelloWorld/monkey.jungle -y /Users/JRENG!/Documents/Digital Poems/Garmin/developer_key -d vivoactive4s_sim -w -l 2
usage: monkeyc [-a <arg>] [-b <arg>] [-c <arg>] [-d <arg>] [--debug-log-level
<arg>] [--debug-log-output <arg>] [-e] [--Eno-invalid-symbol] [-f <arg>]
[-g] [-h] [-i <arg>] [-k] [-l <arg>] [-m <arg>] [-o <arg>] [-O <arg>] [-p
<arg>] [-r] [-s <arg>] [-t] [-u <arg>] [-v] [-w] [-x <arg>] [-y <arg>]
[-z <arg>]
-a,--apidb <arg> API import file
-b,--apimir <arg> API MIR file
-c,--api-level <arg> API Level to target
-d,--device <arg> Target device
--debug-log-level <arg> Debug logging verbosity [0=errors, 1=basic,
2=intermediate, 3=verbose]
--debug-log-output <arg>Output log zip file
-e,--package-app Create an application package.
--Eno-invalid-symbol Do not error when a symbol is found to be invalid
-f,--jungles <arg> Jungle files
-g,--debug Print debug output
-h,--help Prints help information
-i,--import-dbg <arg> Import api.debug.xml
-k,--profile Enable profiling support
-l,--typecheck <arg> Type check [0=off, 1=gradual, 2=informative,
3=strict]
-m,--manifest <arg> Manifest file (deprecated)
-o,--output <arg> Output file to create
-O,--optimization <arg> Optimization level [0=none, 1=basic, 2=fast
optimizations, 3=slow optimizations] [p=optimize
performance, z=optimize code space]
-p,--project-info <arg> projectInfo.xml file to use when compiling
-r,--release Strip debug information
-s,--sdk-version <arg> SDK version to target (deprecated, use -c
-t,--unit-test Enables compilation of unit tests
-u,--devices <arg> devices.xml file to use when compiling (deprecated)
-v,--version Prints the compiler version
-w,--warn Show compiler warnings
-x,--excludes <arg> Add annotations to the exclude list (deprecated)
-y,--private-key <arg> Private key to sign builds with
-z,--rez <arg> Resource files (deprecated)
* The terminal process "java '-Xms1g', '-Dfile.encoding=UTF-8', '-Dapple.awt.UIElement=true', '-jar', '/Users/JRENG!/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.7-2022-11-21-562b8a195/bin/monkeybrains.jar', '-o', 'bin/HelloWorld.prg', '-f', '/Users/JRENG!/Documents/Digital Poems/Garmin/HelloWorld/monkey.jungle', '-y', '/Users/JRENG!/Documents/Digital Poems/Garmin/developer_key', '-d', 'vivoactive4s_sim', '-w', '-l', '2'" terminated with exit code: 100.
manifest.xml
<?xml version="1.0"?>
<!-- This is a generated file. It is highly recommended that you DO NOT edit this file. -->
<iq:manifest version="3" xmlns:iq="http://www.garmin.com/xml/connectiq">
Use "Monkey C: Edit Application" from the Visual Studio Code command palette
to update the application attributes.
<iq:application id="37fc5549-ac6d-4ac8-9f1f-efd94d8a0828" type="watchface" name="@Strings.AppName" entry="HelloWorldApp" launcherIcon="@Drawables.LauncherIcon" minApiLevel="3.2.0">
Use the following from the Visual Studio Code comand palette to edit
the build targets:
"Monkey C: Set Products by Version" - Lets you add all producs that meet the
minimum SDK version of the application
"Monkey C: Edit Products" - Lets you add or remove any product
<iq:products>
<iq:product id="instinct2s"/>
</iq:products>
Use "Monkey C: Edit Permissions" from the Visual Studio Code command
palette to update permissions.
<iq:permissions/>
Use "Monkey C: Edit Languages" from the Visual Studio Code command
palette to edit your compatible language list.
<iq:languages/>
Use "Monkey C: Configure Monkey Barrel" from the Visual Studio Code
command palette to edit the included barrels.
<iq:barrels/>
</iq:application>
</iq:manifest>
Did i missed something?
I haven't tried to develop on Eclipse. Because i'm way more familiar and comfortable writing on VS Code.
Please help.
Thank you.
