Hello,
I have a boolean-property which stopped working, i.e. its value upon invoking
Toybox.Application.Properties.getValue("somePropertyKey")
is 'true' regardless of whether it is set to true/false in properties.xml;
Since it used to work I have changed SDK and found out it worked properly with older SDKs,
i.e. leaving code+properties intact (w/ the prop set to 'false'),
and only changing the SDK being used to compile/run, then compiling+running yield the following results:
- connectiq-sdk-mac-4.1.1-2022-03-14-18db583bc: Properties.getValue return false, i.e. as expected
- connectiq-sdk-mac-4.1.2-2022-04-07-15e8df3ed: Properties.getValue return false, i.e. as expected
- connectiq-sdk-mac-4.1.3-2022-05-10-b3aaee541: Properties.getValue return TRUE instead of false
- connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee: Properties.getValue return TRUE instead of false
Am I missing something or is that a bug ?
