[Help needed, any support available?] Unable to start course navigation
I’ve developed an API which returns Fit file for Garmin Edge devices, which is hosted on Amazon AWS server, below is the way I am retrieving it from the server, I get the response successfully, but I am unable to start track navigation after getting the FIT file
function onReceive(responseCode, data){
      if (data != null) {
var nav = data.next();
            System.exitTo(nav.toIntent());
    function getNavigation(url as String){
        var isUserLogged = Application.Storage.getValue("isUserLogged");
        if(isUserLogged == true){
            var params = {
                var options = {
                    : method => Communications.HTTP_REQUEST_METHOD_GET,
                    : responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_FIT
            Communications.makeWebRequest((url), params, options, method(:onReceive) );
I’ve tried the documented method demonstrated below, but unable to start the navigation, I really need help or direction from here because entire code has been studied from the ConnectIQ documentation, but still somehow it is not working.
//result when navigation recieved
        if (data != null) {
            var navigation = data.next();
