Details: Could not find symbol 'onSelect'.___menu in WatchFace___.
Hello, I need help with this menu.
This works for me by default and correctly:
addItem(new Item(:Apnoe, "Apnoe", Rez.Strings.Apnoe, null, Application.Properties.getValue("Apnoe")));
When i try to add this line to the menu i get an error in the simulator:
Buzz = new Ui.MenuItem(Rez.Strings.Buzz, null, :Buzz, null);
self.addItem(Buzz);
Here I connect the onSelect function:
class SettingsMenuInputDelegate extends WatchUi.Menu2InputDelegate{
var mode;
function initialize(mode) {
self.mode = mode;
Menu2InputDelegate.initialize();
function onSelect(item){
item.onSelect(mode);
I'm asking for help, what should I modify so that the menu I'm adding works for me?
Thank you
    Former Member in reply to _psx_
    Hello, I just found out that I received a reply from you.
    I certainly understand that it is difficult to help when you do not have the entire source code available, if you would be willing, I could send it to you via e-mail via your applications as a question to the developers.
    Or I would need you to at least correct the error.
    When I create a function
    and I put the code in it, see below so i get sim error:
    I am attaching the function and thanks for your help.
    class SettingsMenu extends WatchUi.Menu2{
    	function initialize() {
            Menu2.initialize({:title=> "Test"});
            ApnoeItem = new WatchUi.MenuItem(Rez.Strings.Apnoe, null, :Apnoe, null);
            self.addItem(ApnoeItem);
        function onShow() {
           refreshSubLabels();
        function refreshSubLabels() {
            ApnoeItem.setSubLabel(Prefs.getEApnoe().toString());
        hidden var ApnoeItem;
        var mode;
        self.mode = mode;
            var itemId = item.getId();
            if (item.getId() == :Apnoe) {
                WatchUi.pushView(new Picker(Rez.Strings.Apnoe),
                 new PickerDelegate(), WatchUi.SLIDE_IMMEDIATE);
    Thank you, I wrote you an email...
  • but you have forgot to attach your email :-)
  • Not sure why you are doing item.onSelect(mode); on line 12.
    item is a MenuItem.  Comment out that line.
