BufferedBitmap on renders completely black on glance view
Hi! I'm trying to optimize the efficiency of a glance I've written. Drawing all the primitives each time onUpdate() is called slows down the scrolling speed significantly. So I thought I'd render this to a BufferedBitmap once and then just redraw that as long as the data is still the same. However, the BufferedBitmap is just black, there's nothing on the screen.
Here's the code I use in the glance's onUpdate(), with the image caching parts removed so as to highlight the problem.
                var bitmapOpts = {
                    :width => dc.getWidth(),
                    :height => dc.getHeight()
/*                    :palette => [Graphics.COLOR_BLACK,
                            Graphics.COLOR_WHITE,
                            Graphics.COLOR_RED,
                            Graphics.COLOR_BLUE]*/
                var bitmap = Graphics has :createBufferedBitmap ?
                    Graphics.createBufferedBitmap(bitmapOpts).get() as BufferedBitmap :
                new Graphics.BufferedBitmap(bitmapOpts);
                bitmap.getDc().clearClip();
                bitmap.getDc().setColor(Graphics.COLOR_BLACK, Graphics.COLOR_BLACK);
                bitmap.getDc().clear();
                var soc = sd.getSOC();
        	    bitmap.getDc().setColor(Graphics.COLOR_RED, Graphics.COLOR_BLACK);
        	    bitmap.getDc().drawRectangle(0, 0, dc.getWidth(), dc.getHeight());
                var histogram = sd.getGridHistogram();
                var maxValue = sd.getMaxValue(histogram);
                for (var x = 0; x < histogram.size()*2; x++) {
                    var height = histogram[x/2].toFloat() / maxValue.toFloat() * dc.getHeight().toFloat() - 2.0f;
                    bitmap.getDc().drawLine(x+1, dc.getHeight()-1-height.toNumber(), x+1, dc.getHeight()-1);
                bitmap.getDc().setColor(Graphics.COLOR_WHITE, Graphics.COLOR_TRANSPARENT);
                bitmap.getDc().drawText(25, 60, Graphics.FONT_SYSTEM_XTINY, soc+"%", Graphics.TEXT_JUSTIFY_CENTER);
                dc.drawBitmap(0, 0, bitmap);
I also tried using a palette (which means I can't render antialiased text onto the bitmap, but that's easy to fix by just rendering the text onto the screen dc).
No joy. What I am doing wrong?
