Hi all, I just attended the GDVC breakout session about optimal Monkey C. Thank you, Garmin for adding the option to type check! I think type checking can help me find code I'm not using and get rid of it. When I turn type checking on though, I get errors about undefined symbols for this code (simplified). Would you all mind taking a look and giving me tips on how I can get this to work?
if (id == :item_15) {
// this menu option only pops up if routing is enabled for the device.
// But the compiler doesn't know that, and when I run a device that
// doesn't support routing, I get this error:
// Undefined symbol ':request_directions_to_pin' detected.
request_directions_to_pin();
} else if (id == :item_16) {
do_other_things();
(:routing)
function request_directions_to_pin() {
// do stuff
