Code on GitHub: should I remove my app UUID?
Should I remove the app UUID from manifest.xml if I put my code on GitHub?
  • I have mixed feelings about this. I used to think maybe app UUIDs should be kept secret, but after reflection I figured:
    1) People don't seem to mind posting them to github, even the author of Crystal, a watch face with 3 million downloads.
    2) Nobody can do anything special with that UUID unless they have your private key
  • The very first question is why are you putting on github?
    No one else can reuse your manifest ID and publish. Be very, very careful with your developer key though
  • I wouldn't if you already published the app. If you haven't published the app yet, you can keep the repo private. Or when you don't want to do that, I would use a working name for your app and before publishing the app generate a new UUID (that is very easy) and set the correct name.
