I am developing a custom picker menu and discovered a bug that, swipe right does not work on garmin vivoacive 4, but works in simulator. I binded same method to KEY_ENTER and SWIPE_RIGHT, but as I swipe right on actual device on right in executes swipe left behavior (KEY_ENTER runs code as expected).
PS. In code there are numbers instead of Ui.SWIPE_RIGHT but both ways result is the same.
function onSwipe(swipeEvent)
//swipe right
if(swipeEvent.getDirection() == 1)
_picker.next();
//swipe left
if(swipeEvent.getDirection() == 3)
_picker.previous();
if(swipeEvent.getDirection() == Ui.SWIPE_UP)
_picker.add();
if(swipeEvent.getDirection() == Ui.SWIPE_DOWN)
_picker.subtract();
WatchUi.requestUpdate();
return true;
function onKey(keyEvent)
Sys.println(keyEvent.getKey());
if(keyEvent.getKey() == 13)
_picker.add();
else if(keyEvent.getKey() == 8)
_picker.subtract();
else if(keyEvent.getKey() == WatchUi.KEY_ENTER)
_picker.next();
else if(keyEvent.getKey() == Ui.KEY_ESC)
_picker.previous();
return true;
Am I doing something wrong or there is a problem with a SDK ?
