Position.enableLocationEvents not calling the method
Hi all,
I have an App working well.
At the start, this App uses Position.enableLocationEvents to get the initial position of the device. This is working perfect.
Now, I am trying to add the possibilities for the users to acquire a new start position. I use the same methodology as before, but the methods onForcedPosition is simply never ever not called.
Any help is welcome...
onUpdate()
if (ForceAcquisition==true) {
            Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, method(:onForcedPosition));
            ForceAcquisition=false;}
function onForcedPosition(info) {
        System.println("PLEASE SHOW ME YOU WORk");
        InitialLoc = info.position.toRadians();
        Storage.setValue("PositionLat", InitialLoc[0]);
        Storage.setValue("PositionLon", InitialLoc[1]);
        Storage.setValue("DateDZAcquired", GPSFixDateString);
Top Replies
  • I tried both Conti and one_shoot but nothing. The methods is simply not called, whatever the method. I also tried to move the Position.enableLocationEvents in different location, but nothing…
All Replies
  • Take a look at the recordsample in the SDK.  In that case, it enables GPS in onStart() in the AppBase, and the callback is also in Appbase(). (onPosition()).
    Put a println in onPosition() and make sure you are seeing those when feeding in data to the sim.
    What you are seeing isn't a general problem, as I use GPS in a number of my widgets and device apps.
