Menu2Inputdelegate onSelect not responding to item being selected (A custom image item)
This is the MC file contents, the highlighted yellow code is the Menu2InputDelegate, The blue is the pushing of the custom menu code
import Toybox.Communications;
import Toybox.Application;
import Toybox.Graphics;
import Toybox.Lang;
import Toybox.WatchUi;
class TimelineDelegate extends WatchUi.BehaviorDelegate {
public var active = true;
function initialize() {
BehaviorDelegate.initialize();
function onMenu(){
return pushImagesCustom();
//! Create the Images custom menu
public function pushImagesCustom() as Void {
var customMenu = new $.ImagesMenu(80, Graphics.COLOR_BLACK);
customMenu.addItem(new $.CustomImagesItem(:fingerstring, "Reminder", WatchUi.loadResource($.Rez.Drawables.fingerstring) as BitmapResource));
customMenu.addItem(new $.CustomImagesItem(:clock, "Timer", WatchUi.loadResource($.Rez.Drawables.clock) as BitmapResource));
customMenu.addItem(new $.CustomImagesItem(:firework, "Event", WatchUi.loadResource($.Rez.Drawables.firework) as BitmapResource));
customMenu.addItem(new $.CustomImagesItem(:pencil, "Record", WatchUi.loadResource($.Rez.Drawables.pencil) as BitmapResource));
customMenu.addItem(new $.CustomImagesItem(:bin, "Delete", WatchUi.loadResource($.Rez.Drawables.bin) as BitmapResource));
WatchUi.pushView(customMenu, new Menu2InputDelegate(), WatchUi.SLIDE_UP);
//! This is the Images custom menu, which shows an
//! image and text for each item
class ImagesMenu extends WatchUi.CustomMenu {
//! Constructor
//! @param itemHeight The pixel height of menu items rendered by this menu
//! @param backgroundColor The color for the menu background
public function initialize(itemHeight as Number, backgroundColor as ColorType) {
CustomMenu.initialize(itemHeight, backgroundColor, {});
//! Draw the menu title
//! @param dc Device Context
public function drawTitle(dc as Dc) as Void {
dc.setColor(Graphics.COLOR_DK_GRAY, Graphics.COLOR_DK_GRAY);
dc.setPenWidth(3);
dc.drawLine(0, dc.getHeight() - 2, dc.getWidth(), dc.getHeight() - 2);
dc.setPenWidth(1);
dc.setColor(Graphics.COLOR_WHITE, Graphics.COLOR_TRANSPARENT);
dc.drawText(dc.getWidth() / 2, dc.getHeight() / 2, Graphics.FONT_LARGE, "New pin", Graphics.TEXT_JUSTIFY_CENTER | Graphics.TEXT_JUSTIFY_VCENTER);
//! This is the menu input delegate for the images custom menu
//! Constructor
//! Handle an item being selected
//! @param item The selected menu item
//! This is the custom item drawable.
//! It draws the item's bitmap and label.
class CustomImagesItem extends WatchUi.CustomMenuItem {
private var _label as String;
private var _bitmap as BitmapResource;
private var _bitmapOffset as Number;
//! Constructor
//! @param id The identifier for this item
//! @param label Text to display
//! @param bitmap Color of the text
public function initialize(id as Symbol, label as String, bitmap as BitmapResource) {
CustomMenuItem.initialize(id, {});
_label = label;
_bitmap = bitmap;
_bitmapOffset = 0 - bitmap.getWidth() / 2;
//! Draw the item's label and bitmap
//! @param dc Device context
public function draw(dc as Dc) as Void {
var font = Graphics.FONT_SMALL;
var bmXY = dc.getHeight() / 2 + _bitmapOffset;
if (isFocused()) {
font = Graphics.FONT_LARGE;
if (isSelected()) {
dc.setColor(Graphics.COLOR_BLUE, Graphics.COLOR_BLUE);
dc.clear();
else {
dc.setColor(Graphics.COLOR_WHITE, Graphics.COLOR_WHITE);
dc.clear();
dc.drawBitmap(bmXY, bmXY, _bitmap);
dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_TRANSPARENT);
dc.drawText(dc.getHeight(), dc.getHeight() / 2, font, _label, Graphics.TEXT_JUSTIFY_LEFT | Graphics.TEXT_JUSTIFY_VCENTER);
class Menu2TestMenu2Delegate extends WatchUi.Menu2InputDelegate {
//! Constructor
public function initialize() {
Menu2InputDelegate.initialize();
public function onSelect(item as MenuItem) as Void {
System.println("working");
if (item.getId().equals("Reminder")) {
System.println("reminder");        WatchUi.requestUpdate();
} else if (item.getId().equals("Event")) {
System.println("event");
} else if (item.getId().equals("Timer")) {
System.println("timer");
} else if (item.getId().equals("Delete")) {
System.println("delete");
} else if (item.getId().equals("Record")) {
System.println("record");
//! Handle the back key being pressed
public function onBack() as Void {
WatchUi.popView(WatchUi.SLIDE_DOWN);
