I dont know how can I made it wait for one sec.
anyone can help???????????????????????
You can't busy-wait in CIQ / Monkey C (you'll likely trip the watchdog timer, and it would be a bad user experience anyway), and there's no blocking wait() function like C, but you can set a …
If you want to block the UI in a friendly way for 1 second, you can display a ProgressBar (with busy indicator) and use a timer to dismiss it.
thx
You can't busy-wait in CIQ / Monkey C (you'll likely trip the watchdog timer, and it would be a bad user experience anyway), and there's no blocking wait() function like C, but you can set a timer to do something in the future.
e.g. in the source file that has your view class:
import Toybox.Timer;
// in your view class:
var timer;
function initialize() { timer = new Timer.Timer(); }
function scheduleTimer() { timer.start(method(:onTimerTimeout), 1000 /* milliseconds */, false /* don't repeat */); }
function onTimerTimeout() { // do stuff when timer expires }
// view class continues ...
Note that there's a limit to the number of timers an app can create. I think on most (or all) devices the limit is 3. (The documentation says the "default" limit is 3 -- not really sure what "default" is supposed to mean in this case.)
