Drawables not compiling correctly?
I'm new to the community. I am getting the following compile time error:
ERROR: Problem validating a resource file: Element type "shape" must be followed by either attribute specifications, ">" or "/>".
com.garmin.monkeybrains.resourcecompiler.ResourceException: Problem validating a resource file: Element type "shape" must be followed by either attribute specifications, ">" or "/>".
        at com.garmin.monkeybrains.resourcecompiler.DocumentParser.validateResourceFile(DocumentParser.java:313)
        at com.garmin.monkeybrains.resourcecompiler.DocumentParser.addJungleResources(DocumentParser.java:427)
        at com.garmin.monkeybrains.Project.addProjectResources(Project.java:192)
        at com.garmin.monkeybrains.ProjectBuilder.addCIQProjectFiles(ProjectBuilder.java:270)
        at com.garmin.monkeybrains.Monkeybrains.runPRGCompiler(Monkeybrains.java:1497)
        at com.garmin.monkeybrains.Monkeybrains.compileApplication(Monkeybrains.java:1281)
        at com.garmin.monkeybrains.Monkeybrains.run(Monkeybrains.java:2714)
        at com.garmin.monkeybrains.Monkeybrains.simpleMain(Monkeybrains.java:339)
        at com.garmin.monkeybrains.Monkeybrains.main(Monkeybrains.java:368)
But my XML resource file seems to be formatted appropriately:
<drawable-list id="Dot" background="Gfx.COLOR_TRANSPARENT">
<shape type="circle" x="center" y="center" radius="5", color="0x0000FF" />
</drawable-list>
Using SDK version 4.1.4, minApiLevel 3.2.0, Java:
openjdk version "17.0.2" 2022-01-18
OpenJDK Runtime Environment Temurin-17.0.2+8 (build 17.0.2+8)
OpenJDK 64-Bit Server VM Temurin-17.0.2+8 (build 17.0.2+8, mixed mode)
Any help much appreciated, thank you.
Top Replies
All Replies
