is barrel code/data consumes main app memory or it run like external DLL/API so I can move some utils function to barrel and save main app memory?
A barrel is compiled in to your prg and is in your same memory space and in fact adds a bit of additional overhead.
So, no any advantage, is it mean barrel is binary?
it's basically the same implementation as a module which just happens to be zipped (and only supports ciq 2.4+ projects)
So, I can unzip barrel put source (that I can even fix of needed} into source directory,, compile, save memory {or not save if module also takes additional memory}.
So question is, why is barrel for? :-)
It's to share code with other users. If you look at a .barrel file, it's basically just a zip of the barrel project that gets unzipped and compiled when you compile the app..
With my barrels, I often use jungles to just use the source code without actually using the barrel, to save the overhead of using the .barrel file.
