Weird properties case. not changed value actually changed on a real device
I have been dealing with battery display recently.
For all devices, I provide percentage display.
property in resources.xml/properties.xml
zq means battery format, in percentage or days left
<property id="zq" type="number">0</property>
this property has not tag <setting> in resources.xml/settings.xml,which means it is immutable.
I create a new resources directory resources-batterydays.xml and a settings.xml to make it changable for the devices hava this api.
settings.xml
<settings>
<setting propertyKey="@Properties.zq" title="@Strings.h13" prompt="@Strings.h13">
<settingConfig type="list">
<listEntry value="0">@Strings.h14</listEntry>
<listEntry value="1">@Strings.h15</listEntry>
</settingConfig>
</setting>
</settings>
In monkey.jungle, I just include the resources-batterydays merely for the specific devices with that api.
My getBatteryValue function:
function getBatteryValue() {
Sys.println("Properties.getValue zq is:" + Properties.getValue("zq"));
Sys.println("Properties.getValue zq is:" + typeName(Properties.getValue("zq")));
if (Properties.getValue("zq") == 0) {
return System.getSystemStats().battery.toNumber() + "%";
} else if (Properties.getValue("zq") == 1) {
if (System.Stats has :batteryInDays) {
return System.getSystemStats().batteryInDays.toNumber() + "日";
return "-";
Recently I find my release version has weird phenomenon.
After starting, the value of battery display properly.
But if I modify some app settings not related to battery format, the value of battery will be - after saving performed.
It means the value of zq/ battery format is neither 0 nor 1.
How can it be this?
Did I do something wrong?
