VS Code - Build Current Project stopped working
Hello,
I'm using the VS Code extension to write and test an app. For some reason lately I'm not able to build the app using Monkey C: Build Current Project command (previously everything worked without any issues.). When I call the command I see the following in the VS Code terminal:
> Executing task: java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar /Users/valeriykovalenko/Library/Application Support/Garmin/ConnectIQ/Sdks/connectiq-sdk-mac-4.1.4-2022-06-07-f86da2dee/bin/monkeybrains.jar -o bin/Garmin.prg -f /Users/valeriykovalenko/Projects/STAmina/Garmin/monkey.jungle -y /Users/valeriykovalenko/Projects/_IMPORTANT/Garmin KEYS/developer_key -d descentmk2_sim -w <
Terminal will be reused by tasks, press any key to close it.
When I copied the command into another terminal, I noticed that there are no quotes around paths with spaces. After I added the missing quotes, I got the .prg file.
I wonder if anyone can help me to understand what's wrong and how can I fix it? Is it a bug in the VS Code extension or something with my configuration?
Kind regards,
Valeriy
