Big update to prettier-extension-monkeyc
I've posted about prettier-extension-monkeyc before, but I've added a bunch of new features that developers will probably like (well, I've been missing them, so maybe you have too).
The new features it implements for VSCode include:
  • Goto Definition. Point at a symbol, Ctrl/Cmd click, and it will take you to the definition. Or F12
  • Goto References. Right click on a symbol and select "Goto References". It will show you all the references. Or Shift-F12
  • Peek Definition/Peek References. Same as above, but in a popup window so you don't lose your place in the original document.
  • Rename Symbol. Right click on a local, function, class or module name, and select "Rename Symbol". It will rename all the references. It doesn't yet work for class members/methods.
  • Goto Symbol. Type Ctrl/Cmd-Shift-O and pick a symbol from the drop down (which has a hierarchical view of all symbols in the current file). This also appears as an outline across the top of the file.
  • Open Symbol By Name. Type Ctrl/Cmd-T, then start typing letters from a symbol name. A drop down will be populated with all matching symbols from anywhere in your project.
Older features include a prettier based formatter for monkeyc, and a monkeyc optimizer that will build/run/export an optimized version of your project.
[edit: My last couple of replies seem to have just disappeared, and the whole conversation seems to be in a jumbled order, so tldr: there's a new test-release at https://github.com/markw65/prettier-extension-monkeyc/releases/tag/v2.0.9 which seems to work for me on linux. I'll do more verification tomorrow, and push a proper update to the vscode store once I'm sure everything is working]
  • I think that's it. Since they're now enforcing the new SHA256 signatures when side-loading, they're also enforcing them in the simulator.
  • It turns out I had a bug that was preventing the optimizer from actually generating the SHA256 signatures. After fixing that, everything seems to work again.
    I'm running tests, and will hopefully upload a fixed version shortly.
  • v2.0.118 is out.
    This fixes a bug that was preventing the new SHA256 signatures from being written in the optimized binaries. sdk-8.2.2 won't simulate binaries that don't have a SHA256 signature.
  • I'm trying to reproduce this, and haven't been able to. Is there something else in your project? Files in source for example?
    Could you file an issue at https://github.com/markw65/monkeyc-optimizer/issues and include a zip file (or a link to a GitHub repo) with a complete project?
  • The rest of the files are generated by "Monkey C: New Project" using "Watch App" template.
    Please, try this: SampleApp.zip. I generated a new project outside any workspace and copied the code from my post. All user and folder settings are default. VS Code plugin fails.
    P.S., I downloaded my own zip, unpacked it to /tmp, cloned monkeyc-optimizer, ran npm install and npm run build-debug, then node test/test.js --analyze-only --jungle /tmp/SampleApp/monkey.jungle, and it failed the same way as before in expandTypedef and subtypeOf.
  • Thanks - that does it.
  • Here's a simpler, standalone repro:
    import Toybox.Lang;
    typedef Tuple1 as [Number, Array<Tuple1>?];
    typedef Tuple2 as [Number, Array<Tuple2>?];
    var x as Tuple1 or Tuple2 = [42, Null];
    The problem is that when it tries to compute A or B it first tries to determine if one is a subtype of the other - in which case there's nothing to do. In the case of two distinct self-referential typedefs, it "keeps going" until it finds a difference. But at every level these two types are the same, so it keeps cycling through.
    In your case, analysis sees both definitions of Tuple, so a declaration involving Tuple tries to use the union of the two definitions. A build would only see one of the definitions, and shouldn't have this issue. I have a separate project in progress to try to fix analysis to be more selective about which types it considers "possible"; that would fix your example, but not the one above.
    I think I need to keep a map from "active" typedefs to a set of things they're being compared against, and if I ever revisit a typedef and the set already contains the thing being compared, I can bail and say the two types are the same. I think that's sufficient to cover arbitrarily complex cycles - but it's making my head hurt...
    And I think this is mostly self-imposed. The last time I checked, Garmin's type checker treats uses of a typedef name inside its definition as "Any". So Tuple1 above is just [Number, Array?], presumably to avoid this issue...
  • Yes, with this, the reported problem is fixed here too. That was super-fast, thanks a lot!
  • v2.0.119 is out.
    It fixes this infinite recursion issue, and also an issue where the inferred type of an array/object containing a null was too broad.
  • Thanks, call stack size error seems to have disappeared from my real project. But it still fails in SampleApp. I tried "Restart Extension Host" multiple times after updating to 2.0.119, but it didn't help.
    It looks like I got lots of new errors related to enums. Maybe, I'm wrong, and they are not caused by this fix, since I used PMC with "prettierMonkeyC.disableAnalysis": true for a while because of this infinite loop.
    Could you also take a look at this: SampleWorkspace.zip?
    And is it just me, or the analysis is really slow for this workspace? I have multiple sets of generated sources (that are mostly duplicates of each other) for different devices since barrels don't really support exclude annotations, and I have to avoid this by using different sourcePaths.
