Has anyone else noticed that in CIQ 4.1.1 and 4.1.2 that the glance support in the simulator seems to be broken? I haven't changed any code but my glance supporting widgets, which worked fine in the simulator for CIQ 4.0.10 are now acting as if there is no glance when using 4.1.x.
I'm aware of the "Settings -> Glance View" menu option but that's not the issue. The issue is that the device (Fenix 6 Pro, for example) doesn't think it has glance view and, as a result, it not passing up/down key events to the widget. I've also tried entering the widget from the actual glance view but with the same result.
The only workaround I've been able to find is to downgrade the SDK to 4.0.10.
UPDATE: I've submitted a bug report because I can't find any way (setting or UI process) to tell the simulator that the device is running within a glance enabled device.
