Problem with partial upd .. function, please help.
Hello.
I'm sorry to start another thread for OnPartialUpdate.
I know there is a lot on the forum, but I have not found a solution and an example that would solve my problem.
I will try to describe here what I need to call regularly via this function.
I have five slashes that I created in the font maker.
These slashes appear to me instead of seconds, ie 1 slash = first second.
It is like
"Knight Rider Car" reads slashes from left to right in seconds. Wink
The problem is that when I do dc.setClip at the bottom of the screen for slash size, width, height, I get to total time fast.
I would ask someone who could help me with this feature.
The best example of how to proceed.
Here's what I'm trying to do in OnPartialUpdate.
I do dcClearClip in OnUpdate...
Thank you
function onPartialUpdate(dc){
		sleepMode = true;
		dc.setClip(20, 175, 25, 20);
        dc.setColor(Graphics.COLOR_BLUE, Graphics.COLOR_TRANSPARENT);
        dc.drawText(20, 175, $.fontIcon_seconds, $.ICON_SECONDS, Gfx.TEXT_JUSTIFY_CENTER);
  • solved.
    I didn't have OnUpdate
    dc.clearClip ();
  • You need clerClip() only if you called setClip() so if you call clearClip() in DrawSlash is enough
  • Your code works, but it doesn't keep my slash colors as it was in the video.
    OnUpdate = normal
  • probably you don't see all slashes but they increment each second
    where is OPU and DrawSlash?
  • function onUpdate(dc) {
        	if(dc has :setAntiAlias) {
    			dc.setAntiAlias(true);
            View.onUpdate(dc);
             var sec_now = Sys.getClockTime().sec;
             DrawSlash(dc, sec_now -1);
  • I have the OnPartialUpdate function ready, thank you.
    Now I'm trying the same code used in OnUpdate because I have unnecessarily long code for this feature
  • try it, I haven't tested it
    var sec_now = Sys.getClockTime().sec +60;
    for(var i=0;i<7;i++)
    DrawSlash(dc, sec_now -i);
  • it's acting weird :-)
  • var sec_now = Sys.getClockTime().sec +59;
    for(var i=0;i<10;i++)
  • but it can play with opu so ratherb should be
    var sec_now = Sys.getClockTime().sec + 51;
    DrawSlash(dc, sec_now + i);
