If when i start the App (from simuiator and with the phone) i turn isConsoleDetailShown and isConsoleLabelShown to true, I can turn them off and on again but, and this is what i need, if I set them to false and try to change them in the setting screen:
- On the phone, I can flip the value but then i can't same
- On the emulator, I can set successfully (the notify appear) the value but it doesn't change and if i close and reopen the window it reset itself with the original value
Here is the code, the point is that only with these two it doesn' work it but with isBtShown it does work
properties.xml
settings.xml
App.mc (i'm not including not related stuff)
