Why watch faces work well in the simulator and when they are installed on the same real devices they do not work?
This makes development difficult. I think the simulator should improve a lot.
Thanks.
Thanks.
rather not colours, they are good implemented (it means if you use some concours on v4 they can't be seen on 8 colours device or system choose something)
the problem with amoled watches and some M…
As you see ate least 2 person have the same problem (but I think more than 2). So
1. documentation is silent about it
2. sim not enough reflects to device (and this bug is important - it touch the most…
In the sim, by default they run in high power mode, but you can switch to low power (and should to test). There are other things in the sim like turning off activity testing. And for some things you want to simulate data or play back a fit file. There are some things you don't see in the time, like notification messages. On MIP devices colors can look different than on a real device.
What kind of things are you running into?
A simple watch face that only shows the time, for example, with real forerunner 45 or vivoactive 4 devices, nothing appears on the screen but in the simulator, with high or low power mode selected, it works perfectly.
Post your code. (use a code block in the forum (insert>code)
sounds like 2 bugs:
1. the colors you use in your app
2. (maybe?) a bug in the sim that does display them even though the real device doesn't.
Do you mean that there are colors in some devices that make apps not work?
In FR45, FR55 there are less colors, so a color that you see on another watch might be mapped to the background color
the problem with amoled watches and some MIPS (e.g. v4 - I don't why)) is that system clear device before onUpdate so you have to draw everything all. - this a bug in sim
see
forums.garmin.com/.../vivoactive-4-clears-screen-before-onupdate
I think that’s the problem I have.
Thanks.
and remember that some devices have different name and they are "the same" like other (e.g. firstavenger is probably v4)
with this devices is another problem they serve onExitSleep in strange way so you have to move some code to onUpdate (of course if you use in onExitSleep sensitive code)
Garmin people make it very difficult for us.
