EXTENTION FOR DEBUGGING XML
Good afternoon all
Im new to this and have been following the guide, Do i need a specific xml editor from the marketplace. As when i select below i get the error "You dont have an extension for debugging XML. Should we find a XML extention in the Marketplace?"
Thanks
Thomas
*************Running the Program
Before running the program, make sure you have one of your source files (In the source folder with the .mc extension) open and selected in the editor.
  1. Select Run > Run Without Debugging (Command + F5 on Mac, Ctrl + F5 on other platforms)
  2. You will be prompted with the list of products your application supports. Select one from the list.
If all goes well, the simulator will start up and the selected watch will appear: ***************
