How long is a widget visible?
When you open a widget, after some time it returns to the watch screen. This time varies widely per device. I have a Fenix 3, and it takes about 2 minutes to return to the watch, so you can use the Timer Widget that I developed (https://apps.garmin.com/en-GB/apps/3293c9b6-ed58-4853-86c6-bc5859508d2e). I got feedback that for a Vivoactive a widget returns to the watch screen already after 15 seconds, which makes the Timer Widget quite useless.
  • Is there information how much time it takes for each device?
  • Can you share how much time it takes on your device?
  • The vivoactive is actually 10 seconds (in most cases) and is the "odd one", as the other devices are a minute or two. On the va if you tap the screen every few seconds, that will give you 10 from when you tap, but that's not really a solution. Why not do it as a watch-app instead of a widget?
  • Thanks, that it good to know.
    The reason I chose for a widget is because I wanted a quick and simple repeating timer. There are several timer apps already, and it takes several clicks to get there, then a few more to make it just count down, as there are usually many more options. As a widget, it is just one click away from the watch screen, and it can be run while another app is still running.
