In ConnectIQ SDK 4.1.1 running the simulator, recoveryTime and respirationRate seem to always return null, even on supported devices.
I set the minimum API level to 3.3.0 and 4.0.0, and still no values.
hi, works perfectly on my side in the sim for VA4s and Venu2, what could help you is to post a part of your code where you call them?
Hello, Thanks I found the error in my code. Respiration rate is working now on those 2 devices. However recovery time is not available on the Venu 2. It is available on the VA4S and Fenix 7X.
I did find a bug:
For the bug/error, just restart the sim after you switch targets. See https://forums.garmin.com/developer/connect-iq/i/bug-reports/epix2-no-system-data-in-simulator-system-getsystemstats-symbol-not-found-error
