Accelerometer reference frame?
Hello,
I'm trying to get accelerometer data from Garmin watches - the accelerometer data seems to be relative to the watch itself (vector Z is normal to the watch face), e.g. if the watch is flat on a table, Az will read -1000 or so, and if the watch is on its side on a flat table, Az will read 0 or so.
The recent watches however seem to have a gyro - they therefore should be able to give acceleration along the Z axis of not the watch, but the place I'm at (e.g. the vertical axis, normal to flat ground), regardless of the orientation of the watch itself. This is what I'm trying to get - but I've seen there is no way to get gyro data, so my assumption is that it's impossible.
Is that correct?
Thank you!
